Corvette Vagabond gets his hands dirty , the underbelly of corvette ownership
How to remove and install a haft shaft with new u joints on your back.
When you hear the squeak, then the clank, its time to replace a u-joint. I drove most of the summer, hoping my haft shaft would not be sitting next to me . So it was time for a repair.
Not having a lift was a small problem, because you can not get leverage on the torque wench to break the flange bolts. It will hit the floor. I had to turn the wheel a bit then pull.
The time to do the job was about 2 hours. Not counting the local shop that pressed in the u -Joints for a few dollars. The joints cost about $25 more less a piece. They may have had on them 30 or 40 thousand miles on them since 2011.
First Take Off Spare Tire Carrier
[Bild: 1Takeoutsparecarrier_zpscd2eb7d5.jpg]
Not a lot of room
[Bild: UnderbellyofCorvetteownership_zps6c7cd8e5.jpg]
Put car up on Jack Stands and then Jack below wheel, used to lift & lower wheel to release haft shaft from flanges on rear and hub.
[Bild: 3Putjackundertire_zps648b9aca.jpg]
Tools ready, 5/8 and 9/6 wrench and socket for outer and inner bolts and nuts. Torque wrench 75 & 65 Ft lbs. I had a cheap one that only goes to 75.
[Bild: 2PutcaronJackstands_zpsfec7d040.jpg]
The problem is height of wheel off floor. My wrench would hit floor , so I would have to turn wheel for each little turn. Notice the leg work.
[Bild: 5Pullhardtorqwrench_zps0bb4921f.jpg]
[Bild: 4loosenbolts_zps37ae69a1.jpg]
Haft Shaft Back from shop with U joints inserted.
[Bild: 6HaftShaftNewJoints_zps8fc44451.jpg]
Installing shaft, I used jack to raise wheel to bring haft shaft up and lock in u-joints in flanges. You do not need to loose any cams nuts for rear alignment shafts. Everything goes right back into place.
[Bild: 7InstallHS_zpse736705a.jpg]
Job done ! It took me about 30 minutes to remove shaft. Much faster if you had a lift. Took car out and ran it up to 100 + mph and the haft shaft was not sitting next to me. Must have done it correctly.
You have too, you can do it. Total cost about $60 including pressing in joints.
[Bild: 8JobDone_zps3b4a54e5.jpg]
Join the Corvette Vagabond Community
Like me on Facebook
Follow me on Twitter
My website
