GM hat Probleme mit der Corvette Produktion......
To: All Corvette Dealers
Date: December 15, 2005
Subject: Corvette Production Disruptions
Coupe & Convertible Production
The wheel supply for Corvette has experienced significant disruption. Unfortunately, this situation has caused GM to make several adjustments affecting wheel options, production volumes and production schedules. Many orders may need to have wheel selections changed based on wheel availability. Since timing is critical, and current wheel supply is uncertain, Order Fulfillment / Distribution is unable to follow the normal process of returning orders to dealers for necessary changes. Regrettably, polished wheels will not be available from our new supplier. This will force us to change all orders scheduled to be built after 1/3/06 to Silver Painted wheels. The much anticipated Chrome wheel option will be postponed until late spring production. Any substitution of a lower cost wheel will be reflected in a reduced MSRP and invoice. Additionally, overall wheel availability may delay production dates of "In System" orders.
Z06 Production
The impact to Z06 production is still undetermined as is the future availability of the polished wheel option. Some orders may need to have wheel selections changed based on wheel availability. As is the case with Coupe & Convertible, wheel availability may delay production dates of "In System" orders. Dealers will be advised of their future Z06 allocation outlook as soon as production schedules can be solidified.
Summary
As orders are changed, Order Fulfillment will notify affected dealers via GM Messenger. Order Guides, GM AutoBook and Order Workbench will be changed as soon as practical to reflect the change in wheel options.
We sincerely apologize for the inconvenience and disappointments this situation may cause you and your customer(s).
Danke für den Beitrag. Endlich haben wir es schwarz auf weiß, oder in meinem Fall weiß auf blau! Prost!
1992 C4, 2003 C5, 2003 C5 Convertible, 2006 C6 Z06 - alle verkauft  Kopfschütteln
Gut, dass ich die Z ohne polierte Felgen bestellt habe.
Vermutlich bekomme ich sie am Schluss auf Holzrädern ausgeliefert. King
Im Corvetteactioncenter gibt es auch eine Meldung, die aber hauptsächlich auf den Hersteller selbst eingeht.
könnte das mal bitte einer in 2-3 Sätze auf Deutsch zusammenfassen um was es genau geht bzw. wenn es betrifft.
Irgendwie kapiere ich nicht alles in dem Text. besoffen
Danke und Gruß
Olly
[Bild: olly_sig.gif]
Danke und Gruß
Olly
Nix polierte Räder! Teufel
Gruß, Jan Blaulicht
GM und Dienstleister haben wohl zu viele Mitarbeiter entlassen! Dachten wohl das nur noch Japaner
gekauft werden und das Geschäft weiterhin sehr schleppend läuft! Aber solche Engpässe sind ja leider
üblich - teilweise auch verständlich!
Danke und Gruß
Olly
Danke JAN für deinen hilfreichen und tollen Beitrag auf eine anständig gestellte Frage.Pokal
Wenn Du nur zum Thema ÖL was beitragen kannst,dann halt dich doch in Zukunft einfach zurück.
Ohne Gruß
Olly
Hallo Little
Es geht wohl darum, dass alle C6en, inclusieve die Z06en, die mit polierten oder chromierten Felgen bestellt wurden, mit silber lackierten Felgen ausgeliefert werden, da der Lieferant nicht imstande ist, zeitlich zu liefern.
also :
Zitat:Nix polierte Räder! Teufel
ist schon richtig. OK!
Nee, es geht darum, daß Mr. Hill der Abschied etwas versalzen
wird (in wessen Verantwortlichkeit auch immer) durch ein "Panne" mit
dem Felgenzulieferer Amcast, der einerseits nicht mehr kostendeckend arbeiten konnte
und andererseits wohl von GM zu sehr in die Zange genommen wurde.
Jetzt mußte er zum zweiten Mal in diesem Jahr bankrott nach Chapter11 (Ami-Eigenart)
anmelden. Dadurch kommt es zu Lieferverzögerungen.
  Problem mit Kenwood Radio Corvette C6 lanz1810 10 1.342 27.05.2026, 18:28
  Was kostet der Austausch der Windschutzscheibe bei der C6 mit HUD? UncleRobb 77 68.664 25.11.2025, 14:14
  C6 Fenster macht Probleme beim schließen Duffy 13 18.071 17.06.2025, 11:00
Letzter Beitrag: KSamanek
  CABRIODACH PROBLEME VetteCH 3 2.014 30.04.2025, 10:06
  ls3 Kaltlauf probleme (2 Min.) CheviBert 2 2.836 06.01.2025, 22:13
Letzter Beitrag: CheviBert
