engine
hi can enyone help how can i find out witch engine my 1968 corvette was original with
327-350-427-454 i have the frame number and the body number
gruss
Alan
try this, there is all the information you need:
https://100megsfree4.com/corvette/1960/vet69.htm
Best regards!
Marco
[Bild: bannercag2.jpg]
hi
thank you for the answer
very fast here in germany
best wishes from denmark
Alan
hi Marco
my number is 194678s427808
so i have 2 choises 327 or 427 in different versions maybe you can help
regards
Alan
Sorry, it is not possible to locate the origin engine and it's version from just the VIN.
If you can still find the tank sticker on top of your gas tank you may have a chance for veryfying.
Kind regards
did you find the option code sticker on the tank? There are all RPO´s including the engine.
You refered the engine number? The digits 9 and 10 should give the answer.
Best regards!
Marco
Or better you can ask a Forummember "Porter" he has a BB C3 and I´m sure he has photos of his engine bay Feixen
hi Frank
i will try to find the sticker on the tank
than i will tell you witch engine it was original
regards
Alan
Engel
Hi
By looking at some features of your car, you might be able to eliminate certain engine options from your car,
like, how many steel fuel lines are there ? if only 1, you could have had a 427 hi-performance car.
Number of leaves in the back leaf spring, 7 or 9
type of drive half shaft caps, red line RPM ,
and some more.
It will be nearly impossible to pinpoint it all the way down to only one engine ( type ) without the tank sticker, window sticker.
Good luck. Gunther
hi Gunther
i can tell that the car has no options
no powerbrakes
no powersteering
no aircon
a really hardhitter
paint code is 900 --- tuxido black
trim is 402 black leather
it is a littel different than normal
regards
Alan
how do you tell that it has been that way ever since ?
.....there is only a best guess after about 35 years what it might have been if you do not have the tank sticker. original engine and casting dates of some of the stuff might help.....but still....you can't be sure about every detail.
  81er Engine Temperature Switch für Auxiliary Fan oll-doll 9 4.082 12.09.2025, 19:12
Letzter Beitrag: oll-doll
  Check Engine, Fehler 23 Maverick1964 7 11.722 07.01.2021, 12:34
Letzter Beitrag: caprice83
  Check Engine - ohne Code Peter95 18 29.486 14.05.2020, 14:31
  Keine Check Engine Lampe Mocse 3 6.155 09.04.2020, 19:17
Letzter Beitrag: Mocse
  Check Engine Rolf D. 18 20.409 16.09.2019, 16:45
Letzter Beitrag: thetechguy1
