Themen: 3
Baureihe: Camaro Z28
Baujahr,Farbe: Bj.98, Schwarz
ich habe 2 Fehlercodes, hat jemand diese Codes schon mal bei seiner Corvette gehabt und was ist möglicherweise die Ursache dafür?
Die Codes sind:
P 0481 (hat wohl etwas mit dem Lüfter zu tun)
P 0804
Danke für eure Hilfe
Gruß Marcus
Themen: 4
Hamburg
Baureihe:
C6 Z06
Baujahr,Farbe:
2008, dunkelblau
Habe es leider nur auf englisch:
DTC P0481 Cooling Fan Relay 2 and 3 Control Circuit
Ignition voltage is supplied directly to the cooling fan relay coil. The PCM controls the relay by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the controlled component. Each driver has a fault line which the PCM monitors. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential of the circuit should be high (near the battery voltage). If the fault detection circuit senses a voltage other than what the PCM is expects, the fault line status changes causing the DTC to set.
The relay controls the high current flow to the cooling fans. This allows the PCM driver to only have to control the relatively low current used by the relay.
Conditions for Setting the DTC
The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match
Conditions for Clearing the MIL/DTC
- A last test failed, or the current DTC, clears when the diagnostic runs and does not fail.
- A history DTC clears after 40 consecutive warm-up cycles, if failures are not reported by this or any other emission related diagnostic.
- Use a scan tool in order to clear the MIL/DTC.
DTC P0804 Skip Shift Lamp Control Circuit
The ENG IGN mini fuse supplies an ignition voltage directly to the 1 to 4 Upshift Lamp. The PCM controls the lamp by grounding the control circuit via an internal switch called a driver. The driver supplies the ground for the component being controlled. Each driver has a fault line which the PCM monitors. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential of the circuit should be high (near battery voltage). If the fault detection circuit senses a voltage other than what is expected, the fault line status changes causing the DTC to set.
The PCM detects that the commanded state of the driver and the actual state of the control circuit do not match.
Jan Ole
Themen: 3
Vielen dank mal für die Info, mal schauen ob ich den Grund finden kann.
Gruß Marcus
Themen: 3
habe den Fehler P0804 gefunden, da war die Birne der Kontrolllampe defekt...
Aber leider finde ich den P0481 nicht. Relais und Sicherungen sind in Ordnung, Lüfter funktionieren auch.
Hat vielleicht jemand eine Ahnung ob man irgendwoher einen Stromlaufplan bekommen kann im www?
Marcus Schmitt
Themen: 3
Vielen Dank für die schnelle Hilfe, wenn ich die Lüfter brücke laufen sie an.
Marcus
Themen: 165
Düw
Baureihe:
C5,C6
Baujahr,Farbe:
schwarz
Baureihe (2):
schwarz 04
Baureihe (3) :
schwarz
Baujahr,Farbe (3) :
Dodge Magnum
die Relais haben wir schon getauscht.
Auch den Sicherungskasten haben wir uns aus einer anderen Vette geborgt.
keine Veränderung :-(
Themen: 20
Schland
Baureihe:
C5 Z06
Baujahr,Farbe:
2002 gelb
Zu dem obigen Problem kann ich leider keine Lösung anbieten,
aber falls jemand mit dem Fehler:
P 0430 H C: TWC System Low Effiency Bank 2-A was anfangen kann (Kat-Werte stimmen nicht, sagt zumindest Gearchatter), bitte melden.
Ebenso zeigt mir das DIC noch folgende aktuellen Fehler an:
B 0502 HC: RH DRL Relay Circuit
B 0507 HC: LH DRL Relay Circuit
Sind diese schlimm?
